Craftsman won't start
Ryan
09-01-2002 21:16:06
I dropped the deck and changed the mowing belt on a 20.5 HP rider. Everything went fine. Re-attached the deck. Now it won't turn over and start. (It did fine before). Could something have gotten misadjusted? Battery is 3 yrs old, but shows on the charger as fine.
Lou
09-02-2002 08:28:11
 Re: Craftsman won't start in reply to Ryan, 09-01-2002 21:16:06
If you mean absolutely nothing happens when you turn the key, you have probably disturbed the mower PTO safety switch.
Ryan
09-02-2002 08:48:26
 Re: Re: Craftsman won't start in reply to Lou, 09-02-2002 08:28:11
It will do nothing, or attempt to crank, but it really can't. How would I fix this?
Lou
09-03-2002 15:07:22
 Re: Re: Re: Craftsman won't start in reply to Ryan, 09-02-2002 08:48:26
Put everything in neutral with the brake on and connect a jumper cable form the positive battery terminal to the big nut on the starter. If the starter cranks, you have a switch or solenoid problem.
