Deere 314 need help!
DWS
09-03-2002 10:28:19
got my 314 back from dealer, said head gasket was damaged ,replaced + new plug, points and timing. new air filter. they put it back together and test mowed. at home, can only mow for approx. 20 min, loses power, starts to ping and knock, blow smoke, runs OK when i turn off the deck. needs to cool for an hour+ then i start it up, mow for 20 min., same problem. what should i look for? dealer does not have a clue other than a rebuild of engine ( it does use a little oil)
pete
09-05-2002 08:51:34
 Re: Deere 314 need help! in reply to DWS, 09-03-2002 10:28:19
Possible coil.
Lou
09-03-2002 14:56:12
Did anyone pull off the shrouds to see if the fins were clogged with mice nests or anything?
Robert
09-05-2002 03:59:26
 Re: Re: Deere 314 need help! in reply to Lou, 09-03-2002 14:56:12
Try cleaning the gas tank fuel filter and cut-off valve. Had the same problem with my 214, and this was the problem. Be sure to take the cut-off assembly apart and clean it real good. I also cleaned the gas tank while I had it off.
