Please help MTD tractor
AC
09-14-2002 23:13:31
Hello, I have a MTD 60's or early 70's tractor that has a steering problem. While I drive it around the steering wheel drops a half inch and I have to pull up on the wheel to get it to turn. Does anyone have any suggestions on how to fix this and is this a easy fix? Also the sheet metal is battered at the steering. Is the sheet metal repairable? Thanks for any and all help in advance.
AC
09-15-2002 09:53:15
 Re: Please help MTD tractor in reply to AC, 09-14-2002 23:13:31
Thanks for the help guys. I have another question. Are parts easily available for this tractor? Thanks again.
Mac
09-15-2002 10:11:08
 Re: Re: Please help MTD tractor in reply to AC, 09-15-2002 09:53:15
You might check with rowerdink.com or Jacks small engines.com on parts
Mac
09-15-2002 08:38:23
Probably worn bad over years. I am with lou, if you cant rebuild the assembly, use a spacer. Doubtful if you can find any ready made sheet metal. Battered sheet metal is easy to fix, who knows maybe this is the steering problem. Could have thrown steering shaft out of alignment.
remnutt
09-15-2002 13:36:27
 Re: Re: Please help MTD tractor in reply to Mac, 09-15-2002 08:38:23
go to www.mtdproducts.com, try the tech or the customer support. thay have been good helping the past
Lou
09-15-2002 08:01:01
Don't know anything about that tractor, but a judiciously applied hose clamp might help.
