Ag type tires-yes or no?
kevin
09-16-2002 21:30:00
Greetings:
My currently used lawn tractor- well, let's call it a riding mower, is a Craftsman YTV-16. Tractor is a misnomer with these vehicles because they are sorely lacking in traction. Of the 16 hp. available, maybe 1hp. makes it to the ground. Would field tread ag-type tires actually give me some pull with this thing? I will spend the hundred bucks if it would actually turn this mower into a tractor. These "turf tires" might as well be slicks as far as I can tell.
Thanks for your advice,
kevin
Duully
12-02-2005 21:40:39
 Re: Ag type tires-yes or no? in reply to kevin, 09-16-2002 21:30:00
I have a FF 18 and it was delivered with turf tires. It took them 2 weeks but the got me the 26/12/12 Goodyear terra tires and I've never regretted it!
Hank Daniel
09-20-2002 21:32:27
More weight, wheel weights or other amount bolted to the rear panel of the tractor between the rear wheels. and this would be cheaper.
Q-Ball
09-18-2002 09:33:01
Have you considered adding a set of chains?
kevin
09-18-2002 18:04:36
 Re: Re: Ag type tires-yes or no? in reply to Q-Ball, 09-18-2002 09:33:01
I have a set of 2-link chains, but don't want to run around with them year-round. I have an 8N with regular field tires on it and these don't tear up the yard too bad like I know it does with chains. I want the same thing for the lawn tractor. I just didn't know whether they would add much bite to a something as light and overpowered as a lawn tractor, hence the tire question.
tnx
kevin
David
09-17-2002 17:57:11
Keep in mind that these tires are unidirectional. They work great for forward motion but spin easily in reverse. I have a set of Carlisle Super Lugs on my Craftsman and they make all the difference.
Fritz Campbell
09-17-2002 16:50:07
I've got two JD 140s with fluid (windshield wash)filled ag tires - wouldn't mow without them. I can climb some pretty steep banks with them.
Maybe a few stray marks in the yard if its real wet - but they disappear quickly. Beats having your garden tractor "take off" on you going down hill and you end up riding it out. Pretty scary.
I'd stay with WW fluid or anti-freeze. Neither is as heavy as Calicum but you won't be replacing your wheels either. Good luck!
Nathan(GA)
09-17-2002 21:11:02
 Re: Re: Ag type tires-yes or no? in reply to Fritz Campbell, 09-17-2002 16:50:07
I've got a 140 also. I had the ag tires. The sidewall split on one. I put the wheels and turf tires off my cub on it to make do. Nowhere near the traction. I bought new ag tires 23x8.50-12 4 ply for $29.99 each. Now I got to find some more wheels. The water ate mine up on the inside.
Smitty
09-17-2002 14:49:27
www.tuckertire.com has ag tread tires for lawn and garden tractors. No affiliation but a satisfied customer
kevin
09-17-2002 10:50:46
Okay folks, who sells them for lawn tractors? I looked in the archives and found a reference to Gemplers, but I think they're kinda high esp. since they'd have to be shipped. Anybody else?
tnx
-kevin
Glenn(WV)
09-17-2002 14:50:35
 Re: Re: Ag type tires-yes or no? in reply to kevin, 09-17-2002 10:50:46
Try these places:
www.cedarrapidstire.com
www.millertire.com
You can also get them at places like Tractor Supply. If they don't have the size you want, ask them to order it.
Tommy D
09-17-2002 09:15:16
As an experiment, I put a 50/50 mix of antifreeze & water in the tires of an old rider we have (Murray 12 hp). I know it's not that much weight, but seemed to make a LOT of difference.
It was easy to do with the inflator thingie from TSC I got for my Ford 4000.
Just a thought....
Tommy D.
buck
09-16-2002 22:09:10
I have a friend who has a very steep lawn so on his Craftsman mower he uses full rear wheel weights and ag type tires on the rear. He also weighs about 250. Gets very little wheel spin but it does tread the lawn. He also uses this set up with chains for snow removal. I think all the add on components are Sears.
JT
09-18-2002 17:29:20
 Re: Re: Ag type tires-yes or no? in reply to buck, 09-16-2002 22:09:10
I HAVE A 1650 16 (HP) CUB CADET I HAVE 23X10.50X12 AG TIRES WITH 100 LBS WHEEL WEIGHTS WITH FULL OF 50-50 MIX WATER & ANTIFREEZE. IT WORKS GREAT I DO A LOT OF PULLING WITH THIS LAWN TRACTOR.
lucas
09-17-2002 07:22:52
get em,,youl love em..lucas
nicholas kovach
09-27-2002 10:05:46
 Re: Re: Re: Ag type tires-yes or no? in reply to lucas, 09-17-2002 07:22:52
put some weight on it and a good set of lugs on. dont use calcuim it will eat the wheels. you should be able to get the tires at a tire shop that is where i buy mine for my pulling tractor.
