Cub Cadet 1170 Drive Belt replacement
Stan VanSant
09-22-2002 20:02:21
I was trying to change the Drive Belts on my 1170! Did not have a problem with the upper but could not get the lower belt off the crank shaft pulley! How do you pull off the pulley after you take off the PTO? What is the easy way to change the lower drive belt?
