Cub 682 hydrostatic drive shaft trouble
Chris
09-24-2002 07:55:02
All,
The spring pin connecting the last flange to the pump shaft broke. Upon disassembly I discovered that the hole in the shaft has elongated in two directions. Has anyone encountered this problem before? Any suggestions other than taking it all apart and replacing the shaft? Has anyone pulled and replaced this shaft?
Thanks
Jim S.
09-25-2002 07:38:02
 Re: Cub 682 hydrostatic drive shaft trouble in reply to Chris, 09-24-2002 07:55:02
Couple suggestions that might avoid pulling the shaft:
1.) Least risky: Drill the hole and flange out to the next bigger size spiroll pin. McMaster-Carr (www.mcmaster.com) sells all sizes of them. Search for spring pin, I think.
2.) More risky: Weld up the hole a bit and then redrill it to the same size.
chris
09-27-2002 11:07:09
 Re: Re: Cub 682 hydrostatic drive shaft trouble in reply to Jim S., 09-25-2002 07:38:02
Jim,
Thanks for the suggestions. I think the hole is to ellongated front to back to drill out. I have thought of #2 but was told it can be tough to drill the welded area. Looks like we're gonna try it though. Again, thanks for thinking about it.
Regards
Chris
