400 John Deere Lawn Garden Tractor with 27 Johnson Loader
Arnie
09-27-2002 09:01:01
Im having problems with the front pump that mounts to front pto shaft on tractor. Cant seem to keep pump shaft seals in it. Cant get a new pump for it they are not available anymore so what would any of you guys do? Or does anyone know where I could get a pump? What about a 2 stage pump instead of a single stage? please help and thank you for your time in helping me
check for loose bearimgs
09-28-2002 19:55:43
 Re: 400 John Deere Lawn Garden Tractor with 27 Johnson Loader in reply to Arnie, 09-27-2002 09:01:01
or excessive end play and/or bent shaft
Kent
09-27-2002 18:23:09
Hi. This may be a long shot and not cheap, but the John Deere model #20 loader that JD offered for the 400 tractor was a Johnson model #27, so you might go to your local JD dealer and ask about a pump for the #20 loader.
Kent
Arnie
09-27-2002 18:30:13
 Re: Re: 400 John Deere Lawn Garden Tractor with 27 Johnson Loader in reply to Kent, 09-27-2002 18:23:09
Kent thanks i tryed JD and all they can supply me with is the seal kit and pump no longer available
