7hp tecumseh smoke
spyder
09-30-2002 13:37:42
I have a 7 hp techumseh hor. shaft on a ariens roto-tiller, when you start it it runs about 5 to 10 minutes then kinda misses and starts blowing white smoke profusely, it gets oil in the carburator, you can kill it wait about 30 seconds runs fine for about 5 min, then the same thing.
lucas
09-30-2002 16:37:39
 Re: 7hp tecumseh smoke in reply to spyder, 09-30-2002 13:37:42
a dirty air filter will cause this. if a filter doesnt fix it,, the crankcase breather (in the valve cover may be bad) these are the common fixes. a worn out piston rings can cause this also..lucas
