Dumb ? about B-1 Allis
rob
09-30-2002 20:29:56
just Got a very nice Allis B-1 with a 19 briggs but i can not get spark to it i replaced the points and condencer and cleaned the coil and the conections on the thing under the flywheel so Is their a way to test the coil thanks Rob
kent
10-01-2002 20:02:33
 Re: Dumb ? about B-1 Allis in reply to rob, 09-30-2002 20:29:56
Your easiest solution might be to convert it to an external coil. There's an article on that in the Do It Yourself section at the site below -- in addition to lots of other info there on your tractor..
kent
10-01-2002 20:02:32
ironhead
10-01-2002 13:31:04
i think you can test coil, but not sure. i have bought new points and condensors in the past that were bad right out of the box. i would almost have to say try the coil next. your at that hit or miss point. good luck
