12 hp Koler garden tractor engine problems
Pat Decker
10-03-2002 06:42:07
Help!!! After trying all the suggestions
to remedy this problem I still have it
The tractor runs fine for 10 or 15 minutes
then just shuts off
Any suggestions appreciated
john d
10-03-2002 15:09:40
 Re: 12 hp Koler garden tractor engine problems in reply to Pat Decker, 10-03-2002 06:42:07
I had a cast iron Kohler 12hp engine that would shut off when it got hot, and not start again until it cooled. Turned out to be an exhaust valve that would stick open when heated up on a heavy load.
Ray
10-03-2002 07:55:40
Try replacing the ignition condenser, make sure the fuel tank is vented properly (clean the vent hole in the cap)make sure the fuel shot off valve if equipped opens fully and the strainer in the tank is clean, replace the spark plug, make sure the needle and seat in the carb is clean and the float is not sticking in the closed position, jump(bypass) the ignition switch and run it to see if it still stalls and lastly try another ignition coil sometimes they quit when they get hot. Good Luck
don
10-17-2002 20:00:17
 Re: Re: 12 hp Koler garden tractor engine problems in reply to Ray, 10-03-2002 07:55:40
its the coil they fail when they get hot work when they get cool.some times they crack
tom knosp
11-16-2002 21:00:31
 Re: Re: Re: 12 hp Koler garden tractor engine problems in reply to don , 10-17-2002 20:00:17
