1650 check valves
Roy D.
10-07-2002 04:36:45
My CC 1650 is spitting oil out of the hole in one of its check valves. It spits about a foot high at start up, then oozes while the machine is running.
The oil level was fine at start up, I've blown out the valve with an air hose, but no change. Any ideas? Do I need to replace the valve?
Where can I get this part?
Jim S.
10-07-2002 06:31:41
 Re: 1650 check valves in reply to Roy D., 10-07-2002 04:36:45
You need a check valve. Available new for around $75. Also available from a bunch of used parts sellers. You might try Scott Madson, 920-773-2661, he is good to deal with. Has new and used CC parts.
