446 case
john
10-08-2002 12:26:16
Could anyone tell me if all Case446 tractors are real jumpy when going to forward from reverse or vice-versa. It may be the nature of the beast. thanks for advice.
lcalgiers
10-20-2002 17:35:41
 Re: 446 case in reply to john, 10-08-2002 12:26:16
Mine is very touchy as well. You'll find most Case hydraulic owners have necks like football linemen in contrast to the pencilneck (no offense hydrostatic owners) operators of more standard slush-drive power equipment.
Max
10-08-2002 19:59:33
Yes, that's the nature of the beast when using open center hydraulics. These units are really jumpy after changing the hydraulic oil, which shows you how the oil does break down. One way to avoid the jumpy starts is to push the lever down towards the dash and then ease forward. This little trick will also extnd the life of the plastic rub block under the dash. I've got 17 years and over 500 hours on the original rub block by using this technique.
