Draglink
bibs
10-08-2002 20:35:53
I need a draglink for a sears st/16 tractor. Part#9318h. Tried sears and they are unavallable..Thanks bibs
Mac
10-10-2002 12:05:55
 Re: draglink in reply to bibs, 10-08-2002 20:35:53
Gene has the right idea if you cant find a OEm replacement. I did the same thing for a tie rod assembly betwix the front wheels. Works great. Bearing surface even makes for better steering plus you can grease em.
Gene Davis
10-09-2002 20:37:28
I made the ones for the SS-12 I had by using 3/8" swivel ball joints and then threaded a rod to accept them that was cut to the correct length,will be both right hand threads, but worked well for a long time. Gene
Jeb Mccranie
10-09-2002 16:31:18
I have a SS/16 & I got my drag link from sears. It is very hard to get through to them because they have 2 or 3 different numbers.
