Cub Cadet 2160 battery will not charge
Bob
10-14-2002 05:06:45
I have a '96 model Cub 2160. It will no longer turn over without a jumpstart. The battery was just replaced 2 months ago. It will also occasionally blow a fuse when trying to crank the engine. Three questions - Is anyone familiar with similar electrical problems in this model? What exactly are the (2) 20 amp fuses for? Are wiring diagrams available somewhere on the net? Thanks for your help.
Glenn(WV)
10-14-2002 19:08:39
 Re: Cub Cadet 2160 battery will not charge in reply to Bob, 10-14-2002 05:06:45
You might have a short circuit through the ignition switch. A friend of mine has a Cub 1641; he had problems with the battery not charging after 30 minutes of mowing, and the battery would also be dead if the tractor sat for more than three weeks. He had the ignition switch replaced and voila, no more dead batteries.
