Briggs Stratton 12 hp carb problems
Jim.UT
10-16-2002 18:46:59
The Lawnboy lawn tractor I bought at a yard sale worked great for a month then wouldn't start. Got into it today and found that it would fire right up with the aircleaner off. So I bought a new air filter and put it on. Still no start. Took it off. Starts right up. Then I tried it with the air filter on but without the outer foam rubber pre-cleaner. It started but would only run a few seconds then die. I took the filter off again and started it and let it run. It ran fine for a little while then started running ragged. Then it would smooth out for a few seconds then get rough again. I looked down the intake and noticed that gas would pool up in the bottom at the same time it started running rough.
I really don't know my way around these simple little carbs so some basic tips would be very much appreciated. Thanks in advance.
russell
07-20-2003 05:16:45
 Re: Briggs Stratton 12 hp carb problems in reply to Jim.UT, 10-16-2002 18:46:59
float is set to low floods out and fills bottom of carb
Jeb Mccranie
10-17-2002 16:31:51
Sounds like you are flooding. Adjust oyur mixture to get it to run leaner. It might also be the solenoid on the bottom of the carb(if equipped)
Don
10-17-2002 18:44:49
 Re: Re: Briggs Stratton 12 hp carb problems in reply to Jeb Mccranie, 10-17-2002 16:31:51
gas visable in carb means stuck float. Your flooding, clean float; set float so it is level to the body.set jet one and a half turns out
Darren
11-08-2002 22:09:09
 Re: Re: Re: Briggs Stratton 12 hp carb problems in reply to Don, 10-17-2002 18:44:49
Both responses were stupid. For starters, what engine is it. A stuck float could cause the gas to fill the crankcase, and if it was a faulty fuel solenoid it wouldn't get fuel, or it wouldn't affect the engine.
G
10-04-2004 07:45:48
 Re: Re: Re: Re: Briggs Stratton 12 hp carb proble in reply to Darren, 11-08-2002 22:09:09
I have a 17 HP that the float was scraping the side of the bowl and would not let up. Got a new float but that only worked for a year.
