Cub Cadet 149 hydrostatic
Lee Yoder
10-24-2002 05:20:19
I have a 1974 Cub Cadet 149 and every time I mow with it the mower belt comes off the front pulley, in front of the engine. How do I keep it from coming off.
Jim S.
10-24-2002 06:03:33
 Re: Cub Cadet 149 hydrostatic in reply to Lee Yoder, 10-24-2002 05:20:19
-- Grab the center blade and see if you can wiggle it back and forth. Is the center spindle bearing shot? That causes the pulley to wobble and throws the belt.
-- Be sure the idler pulleys up front are free and that they do not wobble side to side. Replace themif they do.
-- Be sure each pulley does not have a foreign object lodged in the V, like a small piece of stick. That will throw the belt.
-- Be sure the belt you use is the exact profile and length that is specified. To be certain, use only genuine Cub Cadet belts. Or get the profile and length measurements off a genuine belt and buy the EXACT belt in another brand like Gates Green.
