Cub cadet 782 just got it.My first.Many ?,s
david
10-29-2002 18:09:04
JUst got it.It,s the first real tractor.I don,t know much about it.I thought if I ask a few questions maybe I,ll get a few ideals.....The tractor has a lot of play in the wheel,,normal?The front axle moves in and out at the pivot,bushing?Is this bushing replacable?(I,m a auto mech.) The tractor seems to have a slight whine w/ running,is this a normal Hydro chararistic?What is the best oil to use if I want to use it in the winter?Synthetic? Hydro fluid?Starter ,how to change.Gas ,if used in the winter what oct.& any additives?Are manuals avalible?
Glenn(WV)
10-30-2002 05:52:32
 Re: cub cadet 782 just got it.My first.Many ?,s in reply to david, 10-29-2002 18:09:04
Manuals are still available; call Cub Cadet at 1-800-800-7310 to order them and have them shipped straight to your door. The manuals will answer a lot of questions.
A small amount of whine is common with hydros - or at least the ones I've used. The BEST hydro oil to use is Case IH HYTRAN fluid. It can be used year-round. Case IH dealers have it, and Cub Cadet dealers sell it under their own brand label. Make sure you use a hydro filter and not a automotive oil filter(some car filters will fit); the car filter won't trap enough dirt to protect the hydro. The dealer is a good place to get the filter. Fleetguard also makes hydro filters for your 782.
782s are great tractors!
dvogtvpe
10-30-2002 03:58:39
check out www.ihcubcadet.com
