Bad key switch or selonoid???
Chris
10-30-2002 11:03:56
I have a Toro Lawn tractor that won't start by using the key, but if I cross the contacts on the selonoid it will start.
do I have a bad key switch or a bad selonoid??
geoff
10-31-2002 20:01:31
 Re: Bad key switch or selonoid??? in reply to Chris, 10-30-2002 11:03:56
bypass all that safety nonsense i had the same problem with a Murray, 2 Lt10's, an Lt8, a Penncraft, a craftsman, a Jacobsen , a Ford, a John Deere 140 and a john Deere 455 if that doesn't work replace the switch.
terry mitchell
10-30-2002 14:30:10
it sounds more like a bad safty swith
lucas
10-30-2002 11:43:53
i would say if your not getting 12volts to the selinoid your key switch may be bad..if you have a fuse check it to..lucas
