Cub 782 front axle steering box
david
11-01-2002 20:04:23
I have a cub 782.the front I beem moves front to back when shaking the steering wheel,about 1/8-1/4 inch.Is this normal ,or is there a bushing in the I beam that can be replaced? Also is the steering box adjustsble?
Jim W.
11-09-2002 00:05:53
 Re: Cub 782 front axle steering box in reply to david, 11-01-2002 20:04:23
I have several 82 series tractors. The front axle play may come from the frame being spread apart to far. I have tightened them up with a hammer and a big C clamp. Your pivot pin probably has some play in it also, but I doubt if it is wore enough to cause that problem. The steering box is easily adjusted. There is a lock nut tightened up around a straight slotted screw. Loosen the lock nut, turn the screw in until tight. Back it out 1/4 to 1/2 turn and lock the nut down tight. It may require some fine tuning to your preference. Jim
