Cold weather oil 80,s Kohler
david
11-02-2002 16:55:40
I have a Cub Cadet w/ a 17 hp Kolher.It doesn,t have a oil filter.I beleve this means it doesn,t have a oil pump,it just splashes the oil.I thought that if you use a tractor in cold weather 35-20 deg. you shuold use 10-30.but a parts person at a local dealer said they use 30w all year it makes them last longer.What should I use? how about a synthetic ?
steve
12-18-2002 15:25:01
 Re: Cold weather oil 80,s Kohler in reply to david, 11-02-2002 16:55:40
My kolher rep will argue all day to only run 10W-30 year round. You engine does have an oil pump as well as hydraulic lifters so oil is important.
tim
11-03-2002 07:02:23
i would use 5-30w but remember to change in spring asap above 40 5w30 to light of oil
lucas
11-03-2002 05:51:00
kohler reccomends 10w30 oil in below freezing temps for your engine.if you keep your tractor in a heated garage you will probably be safe with 30w but 30w gets thick in below freezing temps ,hurting lubrication on starts..lucas
