18 HP Kohler
Bryan
11-13-2002 08:10:45
I have an Kohler Command 18 engine and when I first start it it only runs on 1 cylinder for about a minute then the other cylinder starts to fire but if you accelerate the rpm's it will again misfire for a short period then it straightens up. Any ideas on a remedy or cause?
Bryan
Tony630
11-13-2002 16:37:39
 Re: 18 HP Kohler in reply to Bryan, 11-13-2002 08:10:45
Yes it could be as simple as a fouled plug, but most of the time it is the ignition module-coil going bad. You can check your coil by the manual. It tells you what the resistance should be in ohms.....
Tony630
lucas
11-13-2002 11:46:50
ive seen several doing this and one plug is fouled. cleaning or replacing it makes em run ok. but there is an underlying cause making the plug foul..lucas
