Bought a bolens lawn tractor need questions answered
Larry
11-18-2002 16:45:14
Hello all. I just bought a Bolens with a 12 hp motor. Question what type of engine is this-I cant see any nameplate. ANd it is model #1255. how much engine oil does it hold and how much trans fluid does it hold? thanks
Don
11-24-2002 08:33:21
 Re: Bought a bolens lawn tractor need questions answered in reply to Larry, 11-18-2002 16:45:14
The Bolens 1255 tractors were built for two years. 1255-01 in 1976 1255-02 in 1977 They both used a Tecumseh engine. Model - HH120 Type - 120199E I don't have the other books here with me as far as capacities are concerned but I fill the transmission in my tractor to the fill plug with 90 wt. gear oil (don't remember how many qts. it took) and the engine, if my memory serves correctly, holds 1 1/2 qts. of oil.
Scottey841
11-19-2002 15:37:55
Around what year is the tractor? I know in the 70's they used Wisconsin engines.
Larry
11-19-2002 16:47:48
 Re: Re: Bought a bolens lawn tractor need questions answered in reply to Scottey841, 11-19-2002 15:37:55
It looks like it came out of the 70's. cant tell the name of the motor though. I will look more this weekend for info + proably put in a fuel shut off valve.
scottey841
11-20-2002 09:25:10
 Re: Re: Re: Bought a bolens lawn tractor need questions answered in reply to Larry, 11-19-2002 16:47:48
My dad had a 1400 series Bolen from 1973. It had a single cylinder 14 hp Wisconsin engine. The name plate for the engine was on top of the engine. Maybe yours is missing that plate or it is a different engine. We used that tractor for 26 years. Loved that hydrostatic drive.
dan
11-24-2002 08:18:28
 Re: Re: Re: Re: Bought a bolens lawn tractor need questions answered in reply to scottey841, 11-20-2002 09:25:10
You have a Wisconsin S12-D it gives you 12.5 hp, and you can get parts from WIS-CON total power corp. they still manufacture parts for the engine.
take a look at the set-up of your drive shaft, so if it were to break you would know what you have.
I have an original engine manual that i can copy.
dan
jay
09-10-2003 19:34:32
 Re: Re: Re: Re: Re: Bought a bolens lawn tractor n in reply to dan, 11-24-2002 08:18:28
i bought a 1977 bolens tractor and it's a nice little tractor but i would like to get a manual for it and restore it i have a snow blower for and a mower deck and a rotiller which i know i will probley never use but it's like new but i don't have the owners manual and haven't tryed to figure out how it go's on the tractor any help would be great thanks jay
Larry
11-25-2002 03:01:50
 Re: Re: Re: Re: Re: Bought a bolens lawn tractor need questions answered in reply to dan, 11-24-2002 08:18:28
Yes I would appreiciate that if you could fill me in on this machine. Do know what year my tractor is it is a 100,000 serial #. model 1255.
don
11-24-2002 08:38:05
The S12-D wisconsin was used in the 1250 models and they were a totally different frame tractor than the 1255 and the S12-D will not fit on a 1255.
The 1250 has a channel iron frame and the 1255 has a tube frame and your wheel base is considerably shorter on the tube frame.
