CUB CADET Carb.
George Grubby
11-19-2002 07:27:48
I need a carb. for my Cub Cadet 100 with a KOHLER K341. I don't have any other engine #s
Paul
11-22-2002 18:08:10
 Re: CUB CADET Carb. in reply to George Grubby, 11-19-2002 07:27:48
George, are you sure it has a K341 in it? A 100 came with a K241, 10 hp Kohler in it. A K341 is a 16 hp engine, and to put it in a 100 would require the frame to be modified, or the flywheel and blower housing would have to be changed to a smaller one. The two engines did not use the same carb, and there is nornally a difference in price, even for used ones. Be sure what you have before you buy a carb.
Marlin
11-19-2002 12:24:42
IH REGISTRY CUB CADET FORUM
Link
Try the classifieds in these sites and you will find one real quick and reasonable at that.
Phil B.
11-19-2002 09:31:34
George, The carbs for those are pretty generic.I believe the same carb can be used on 10 thru 14 h.p. Try looking on e-bay, or post a want ad on this site.
