14 horse kolar won't stay running
Paul Visintini
11-19-2002 10:20:57
i have a 14 horse 12 volt system Economy King tractor.replaced starter generator new voltage regulator on tractor will start and run at just over idol.Cannot give throttle it will stall. Any help am going crazy.Thanks in advance. Paul
MIKE
07-31-2003 05:27:51
 Re: 14 horse kolar won't stay running in reply to Paul Visintini, 11-19-2002 10:20:57
will it fit a 1962 cub cadetif so how much.
Mac
11-19-2002 12:43:42
Could be as simple as replacing a fuel filter.
Otherwise sounds like a carb problem.
Dennis
11-19-2002 12:20:25
Sounds like Carburetor problems. Try putting on the choke when you advance the throttle. If it stays running when you do this then you aren't getting enough gas and will need to adjust your carb accordingly. Or could be you have dirt in the fuel line.
