Case 446 with Onan 16 HP
Mike Hodgkins
11-20-2002 16:42:12
Tractor was running great but just stoped . Fuel system seems fine and I have power to the coil. (coil is new) Any suggestions Thanks Mike
Mike Hodgkins
11-26-2002 03:23:38
 Re: Case 446 with Onan 16 HP in reply to Mike Hodgkins, 11-20-2002 16:42:12
Over the weekend I spent some time on the tractor, checking wiring etc.. I did notice that in one of the cylinders that there was alot of moisture(water) coming out of the plug hole when you turned the engine over and also not much compression. Could this be a head gasket or stuck valve
Max
11-20-2002 21:04:30
Do you have spark? Is the carb really throwing a lot of fuel through it? these had a history of weak condensors and the composite floats would swell with gasahol and flood the engine out.
Mike Hodgkins
11-21-2002 05:04:34
 Re: Re: Case 446 with Onan 16 HP in reply to Max, 11-20-2002 21:04:30
I would check for spark at the plug right? (remove plug and turn is over).
steveinct
11-21-2002 10:47:41
 Re: Re: Re: Case 446 with Onan 16 HP in reply to Mike Hodgkins, 11-21-2002 05:04:34
Mike, That's the way to check, at the plug. I had the same thing because of a short that kept blowing fuses. Ran fine, all of a sudden, nothing. Haven't had a condenser problem yet, same one I bought it with, 4 years and probably 400 hours. Good luck, let us know what you find. Steve
Max
11-21-2002 17:27:02
 Re: Re: Re: Re: Case 446 with Onan 16 HP in reply to steveinct, 11-21-2002 10:47:41
They had a recall on the 85's for the condensor replacement but not everybody was advised. A couple of months ago I was using mine to put in a new yard and all of a sudden it lost power and wouldn't even pull a bedspring. Cleaned the points, adjusted and timed it and now it runs fine again.
