1968 14 H Kohler economy power king
Paul Visintini
11-21-2002 17:04:50
Have new generator starter,voltage regulator and new points, checked carb.Now when it starts it will run to low idle and when you give more throttle,watching the points it will idle up and then will be no spark at the points,then it will resume firing and kick off and die. But it will idle all day. Help i am ready to give up.
DAVE
11-22-2002 06:12:51
 Re: 1968 14 H Kohler economy power king in reply to Paul Visintini, 11-21-2002 17:04:50
Paul check your condenser to see if you got it hooked to the + side of your coil I put one on the wrong post and it ran just like your's DAVE
Dennis
11-21-2002 19:59:20
I may be wrong and I'm sure I will hear about it if I am (oh well) however are your points set to fire too soon so that you are firiing too slow at a higher r.p.m.? In other words they are actually closed when you are at fast idle. Let me know if that is what it is.
Al
11-22-2002 03:43:51
 Re: Re: 1968 14 H Kohler economy power king in reply to Dennis, 11-21-2002 19:59:20
The k341 in my jd 300 did the same thing.Turned out to be a poor conection of the ground strap.When reved up,the vibration would break the circuit.Found out when I tried to move the tractor after dark,noticing sparks between the sheet metal shrouds.cheep fix,worth checking(run it in the dark)
lol
Al
lucas
11-22-2002 03:41:16
are you using original kohler ignition parts... i tried after market syuff and it gave me fits like your having,also have seen a worn points lobe on the cam cause this.are your points opening a full 020.setting points with a timing light really sets em good.how about a worn points pluner rod,lucas
