Gang mower service
brent
11-21-2002 19:29:10
I have a set of toro gang mowers. Where can I find service info? How do you sharpen and adjust the knives?
JD790
11-23-2002 11:54:36
 Re: gang mower service in reply to brent, 11-21-2002 19:29:10
I worked in a Toro turf shop in the late 1970's.
It takes a precision real grinder and an operator to grind the reals and bed knives.
when they are assembled They need back lapped and adjusted. The settings are so important to prevent rifling and premature wear on the reals.
Not to mention many need the case halfs split and sealed. It is really a job for service facility that can manage them. A toro commercial shop could look at them and probably give you a flat rate repair per unit.
They typically run winter Specials grinding reals. They can also show you how to keep and check adjustment in the field.
brent
11-22-2002 19:32:06
thanks for the info
tim
11-22-2002 04:49:16
go to your neerest golf corse and ask them who sharpens thers takes a reel grinder and then set bed not a home job
Marlin
11-21-2002 20:05:14
Link
TORO
Consumer Division
8111 Lyndale Avenue South
Bloomington, Minnesota 55420
1-800-595-6841
Link
They should have manuals and tech support here.
