BS 8HP MOTOR FLYWHEEL KEY BRAKES WHEN I START IT UP
TITO
11-25-2002 04:18:11
TUNED UP THE MOTOR AND AS IT STARTS THE FLYWHEEL KEY BREAKS AND IT (OF COURSE) SHUTS-OFF. DOUBLE CHECKED THE GAP ON THE POINTS AND ARMATURE. DONT KNOW WHAT I DID. HELP
rlf
12-03-2002 12:21:55
 Re: BS 8HP MOTOR FLYWHEEL KEY BRAKES WHEN I START IT UP in reply to TITO, 11-25-2002 04:18:11
make sure tje washer is on top of the flywheel before torking. sounds to me it is either missing washer or is not tight enough.
tito
11-30-2002 05:27:26
thank you all for the help and responses. i was able to put the cotton-pickin' motor back in one piece and when i pulled on that dog-gone rope the little bugger started on the first pull! Much to my suprise!
i was very much suprised that i got so many response trying to help me. i was telling my friends and co-workers what a great support network you all have here. TO MY NEW FOUND FRIENDS HAPPY HOLLIDAY!
Jim
11-28-2002 20:07:52
You are not getting your flywheel nut/starter clutch tight enough. it has to be very tight,do not know exactly how much, as I put it on 1/2" impact tight.
ChesleyW
11-26-2002 11:06:49
HAd same problem once, went through 3-4 keys till I figured out I was putting the key in on its wrong side, it had just a little play but once the engine fired it give enough to shere the key.
Mac
11-25-2002 06:39:26
Be sure the washer is on right and put plenty of muscle on the nut.
don
11-25-2002 04:55:02
I am assuming that it has the old style ratchet clutch on top of the flywheel. If you don't get this tightened down enough that could cause your problem.
james mayer
11-27-2002 17:51:36
 Re: Re: BS 8HP MOTOR FLYWHEEL KEY BRAKES WHEN I START IT UP in reply to don, 11-25-2002 04:55:02
if you have the magnatron conversion you need a different key than w/ points. doon't use "key stock" from the hardware it isn't hard enough.
teej
11-29-2002 14:44:43
 Re: Re: Re: BS 8HP MOTOR FLYWHEEL KEY BRAKES WHEN I START IT UP in reply to james mayer, 11-27-2002 17:51:36
Brrigs uses the same aluminum key in all engines, regardless of points or magentron. The problem is the nut or ratchet starter (whichever is used), has to be tighten to the required torque. In this case, tighter is better. The key doesn't hold the flywheel in line with the crank. It only provides a reference to line up the timing. I've run a few engines with no key in there at all. Just line up the 2 key grooves, and torque the nut down.
What actually holds the flywheel and crank together is the taper, and the pressure of the torqued nut. I've never seen a briggs engine points, or magentron that used anything but the aluminum key. I've done many conversions, re-using the key as well.
The key stock from the hardware store should NEVER be used. Its steel. The proper key is aluminum, designed to shear if excessive forces affect the crankshaft. If you use a steel one, you end up with a broken flywheel, crankshaft, or major internal engine damage, or a combination of all three.
