Hello Guys, I am new to this board, but I was wondering if I could get a little help.My grand father puchased a brand new generator in the '80's and it sat in a crate w/o oil until this summer. I put oil in it and installed the plug wire and sure enough it started, and ran well. It has an 8HP Hor. shaft B/S with recoil only. I used it for about 30-40 hr over the summer, and tonite I started it to run a light. I started-first pull, ran a few mins and quit, making all kinds of noises internally(METAL). I loaded it on the truck and took it to the heated shop. pulled on the rope -very easy to pull, normally will upset machine if you don't hold it down and pull! So, I removed the head, and found the piston not attached to the crank. Removed gen and split the case. Found rod in a bunch of pieces, and looks like the brg spun on the crank for a while. My BIG question is, How do I safely remove the flywheel with the recoil end on it? I have read about them shattering if pried on-do not want that!! Also, are rod brgs available undersize to compensate for machining the crank? Where is a good source for Rod, Brgs., Gasket,and Tech Manual Also, what is the usual price to turn a crank? Thank You Very Much in advance, Pat
