Accessories for 214 John Deere
C.D. Long Jr.
12-08-2002 05:52:38
Can any of ya'll tell me what was available for this model JD? Like a sleeve hitch, snow cab etc. I have one that was given to me. It was in a barn for 10+ yrs. Rough shape but runs w/ deck. I'm trying to figure out if I want to rebuild ( has several problems, spark plug stripped, needs new fuel line, some times I have to jump solenoid to crank) or find a any used tractor w/ attachments, ( snow removal & mowing ).I am in need of manuals also! THANKS C.D.
kjm
12-13-2002 20:53:36
 Re: accessories for 214 John Deere in reply to C.D. Long Jr., 12-08-2002 05:52:38
CD, Check the ignition switch,if you take it out spray it good with PB Blaster and it will work(maybe)If you want a complete mower let me know.
Gene Davis
12-11-2002 19:03:05
Put s helicoil thread insert in the head for the soark plug, that way you have steel threads in the aluminun head, and save a bunch of money. It can be put in with out removing the cylinder head if you coat the tap with grease to catch the shavings as you work the tap. Gene
Steve from MO
12-11-2002 11:10:47
I have a 210 and it has been a good tractor. There are lots of attachements available for them but good ones are pricey due to their age.
The spark plug stripped I assume means the threads in the head are stripped. You can replace the head pretty easily, and used parts are available. The fuel line is an hour's work for a klutz like me, and the solenoid maybe fifteen minutes work.
I have manuals if you need to ask a question. Otherwise buy the manuals if you keep the tractor. You will refer to them fairly often.
