Can you rebuild a 17 kolher series I ?
dave
12-09-2002 19:13:34
Can a serreis I koher be rebuilt,succesfully cheaper than a new unit or a short block?What does a short block come with?
Ron
12-11-2002 08:39:17
 Re: can you rebuild a 17 kolher series I ? in reply to dave , 12-09-2002 19:13:34
I lost a rod in a KT 17 about 1980, and the series II cost $1,013.oo THEN...and I installed it... I think I would buy a GOOD used mower with a good series II in it... I got a good new Big Bore Onan short block for $150, at an equipment auction....That is a good Power House.!! I ported it, before I put it in..!! The Series I Kohlers have no pressure oiling.....Dippers on the rods...like the pre 1952 Chevy 6's...Nobody builds them, either...!!!!!
Jim S.
12-10-2002 05:49:38
Kohler does not recommend it. Though I suppose you could. The Kohler bulletin recommends a Series II short block for all Series I engines that need rebuilding.
dave
12-10-2002 17:34:30
 Re: Re: can you rebuild a 17 kolher series I ? in reply to Jim S., 12-10-2002 05:49:38
how much is a shortblock?What does it includ.What would I need in addision?Where should I get one?
Jim S.
12-11-2002 06:11:51
 Re: Re: Re: can you rebuild a 17 kolher series I ? in reply to dave, 12-10-2002 17:34:30
See the link for a replacement KT-17 for yer tractor from Jack's Small Engines. You might also inquire about the Magnum 18, which is pretty much a drop-in replacement engine, too (I prefer the Mag 18).
A short block includes all the internals in the block. You re-use yer old engine's tin, carb, flywheel, etc. You might inquire at Jack's about those, too.
Jim S.
12-11-2002 11:47:19
 Re: Re: Re: Re: can you rebuild a 17 kolher series I ? in reply to Jim S., 12-11-2002 06:11:51
Found this one today, too, Dave.
