Discharge when pto engaged
bob
12-14-2002 12:53:08
Hi I posted a while ago about my craftsman GT , it's a solid machine w/ blade,disc,plow,mower.
Problem is the batterey discharges when the electric PTO is engaged. I have replaced PTO,PTOswitch,seat switch,cleaned connectors etc. what am I missing???. Its a GT6000 w/B & S 2 cyl and manual shift. thanks for any help.
bob
Ben in KY
12-17-2002 13:33:22
 Re: discharge when pto engaged in reply to bob, 12-14-2002 12:53:08
Sounds like a charging system problem to me. And/or a weak battery.
If the discharge only occurs at slower engine speed this may be normal.
Fish
12-15-2002 19:15:14
Once the engine starts, there is no other need
for the battery, unless you have an electric
pto or lights. So your engine has an alternator
large enough to recharge the battery and keep up
with the clutch, as it takes a lot of juice. Fish
charlie z
12-17-2002 15:15:09
 Re: Re: discharge when pto engaged in reply to Fish, 12-15-2002 19:15:14
Bob try replacing the voltage regulator should be on left side of motor on top.
zman
