Case 646 mini loader Transmision Casting
Kees
12-16-2002 08:46:41
Looking for a rear axle transmision casting for my Case 646 serial no 9698993
Paul B
12-21-2002 14:31:26
 Re: Case 646 mini loader Transmision Casting in reply to Kees, 12-16-2002 08:46:41
As long as your 646 is not a back hoe model, a rear from any 444,446, or 448 will work also. I assume the gear carryer bolts broke, and cracked the housing.[only weak point in this REAL tough tractor] If so, most people have had good luck welding up the hole. Where it cracks is not a high load area. Good luck.
Redtractorman
12-16-2002 20:56:21
Go to this yahoo group and post question there.
http://groups.yahoo.com/group/casegardentractors/
Lyle Oakes
12-16-2002 14:03:00
I have a Case 646 bucket loader. I found out that Case sold all there garden tractor business to a company called Ingersol. This is not Ingersol Rand. I needed the bracket that went between the engine and the hydraulic pump. I had to order it from Ingersol and it took 2 months for the part to come in and guess what it was the wrong one and they tell me they can't get the right one. I hope you have better luck. I know the main warehouse for Ingersol parts is in Mass. There are dealers elsewhere. The dealer really tried for me. Maybe I have a odd machine. It has a Kolher engine instead of a Onan. I live in Pa.
Redtractorman
12-16-2002 20:57:35
 Re: Re: Case 646 mini loader Transmision Casting in reply to Lyle Oakes, 12-16-2002 14:03:00
The Case 646's had 16 hp onans and the case 644 had kholer 14 hp engines.
