Case 224 lawn tractor starter/generator??
Dane Shidler
12-26-2002 14:20:18
my father in law has this tractor and has lots of trouble with the electrical system, I am a farmall man myself-- can anyone shed some light
on the way it was from the factory==
Ive heard that it both charges the bat and starts
all in the same package. it just looks like a starter to me. any help would be great!!
Steve-MN
01-06-2003 19:11:12
 Re: case 224 lawn tractor starter/generator?? in reply to Dane Shidler, 12-26-2002 14:20:18
Dane,
I just had mine rebuilt. Very common from the 50's thru early 70's. It's a Delco on my 67 JD 112. Cost me $70 to rebuild the entire thing at a fix it shop. They even painted it. Cub Cadets used them the most they told me.
Good luck,
Steve
teej1898
12-27-2002 16:38:09
It should have a belt pulley on it, and its wired very similar as a generator. The F terminal on the starter/generator goes to the F terminal on regulator, and is usually a 12 or 14 guage wire. Biggest difference is the A terminal on the starter/generator has a battery cable that goes to the start Solenoid. This energizes the starter portion when the key is turned to start so it works as a starter. When you let off the key, and the engine runs, its now a generator. The voltage regulator I believe is wired just like any other system with a generator charging system. I haven't looked closely at the ones on my 3 tractors in a while, but this is what I remember from when I last had to repair one (about 5 years ago)
