Kohler piston/bore clearance
Al
01-14-2003 15:27:39
My manuel lists .003-.005 for the m16 and .007-.010 for the k341.I thought they should be the same.Anyone know.
Thanks
Al
dvogtvpe
01-14-2003 19:10:00
 Re: kohler piston/bore clearance in reply to Al, 01-14-2003 15:27:39
The M16 would use the Mahle style piston.
lucas
01-14-2003 19:45:23
 Re: Re: kohler piston/bore clearance in reply to dvogtvpe, 01-14-2003 19:10:00
be sure to look at the up to date chart on piston clearance. it is important to measue the piston in the proper place. the k341 is measured at a different spot than the m16 piston.
Al
01-15-2003 03:32:42
 Re: Re: Re: kohler piston/bore clearance in reply to lucas, 01-14-2003 19:45:23
My manuel does not mention this,could you explain please.
thanks
Al
