1282 Cub Cadet
Cold Finger
01-27-2003 12:56:12
I just bought my first RED Cub Cadet.It's a very nice one owner 1282 but it has manual lift.Was hydro lift an option for this model?Or was the 1282 a "cheaper" model.I know it can be switched over,but if it's not "correct" I don't want to do it.Also,would a ported hydro from a 149 work if I would decide to make the swap?Thanks!!!
Howard Booher
04-06-2006 05:03:10
 Re: 1282 Cub Cadet in reply to Cold Finger, 01-27-2003 12:56:12
what kind of money did you pay for your 1282?
dave
02-02-2003 20:00:12
Whats a ported hydro?
Cold Finger
02-05-2003 07:38:55
 Re: Re: 1282 Cub Cadet in reply to dave, 02-02-2003 20:00:12
It's a Hydro transmission with extra outlets(ports) to attach a Hydraulic Lift!
Jim S.
01-28-2003 08:32:32
1282 a very good machine, congrats! It is the same as the 682 except it has a 12 hp K301 Kohler engine. Nothing wrong with either the engine or the tractor design, so good job!
The 1282 came with a manual lift. No hydraulic lift was offered, to my knowledge, though as you say it can be adapted to it. If you swap, the ported 149 hydro will work, or the front section off any ported CC hydro will work when bolted to yer existing unit.
If you do not switch to hydraulic lift, I would recommend that you get a helper spring. You can adjust the tension so lifting a 50" deck if almost a fingertip operation.
Cold Finger
01-29-2003 08:04:33
 Re: Re: 1282 Cub Cadet in reply to Jim S., 01-28-2003 08:32:32
It already has the 3-point with spring assist.It does lift easily but,after being used to my 1450 it just seems odd.We'll let the wife mow with it.Heh!Heh!Thanks Guys!!
Bill Earle
04-30-2003 18:09:51
 Re: Re: Re: 1282 Cub Cadet in reply to Cold Finger, 01-29-2003 08:04:33
Does anyone have any photos and dimensions of some
of the 3 pt hitch parts for a 1282?
- Bill
125 Hydro
01-28-2003 05:57:11
Link
Try this site... many wonderful people with the knowledge to help you.
