17TK 782 replacment?
DAveA
02-03-2003 20:15:42
What is the cheapest replacment engine I can drop into my 782?
Donny-B
02-12-2003 19:22:59
 Re: 17TK 782 replacment? in reply to DAveA , 02-03-2003 20:15:42
Unless you have the mounting brackets, wiring harness , and air cooling boxes for a 482 (takes a briggs 11hp) or 582(takes a 16 hp Briggs twin)I would suggest looking for a good running KT-17 series 2.(has full pressure lube rods and mains) The series 1 versions only had oil pressure to the main bearings, not to the rods. If you ran them low on oil or cut grass on a slope, the would blow rods.
