70 JD w/7 horse motor
Fred Kobs
02-06-2003 23:49:32
I have a 70 that had a Tecumseh on it. I do not know the size off the top of my head but I can't find (of the 4 I looked at) a small enough shaft to fit the pulley and there isn't enough meat in the pulley to machine out for larger dia. crank. Is the smaller crank a JD only thing? I have a 7H briggs & 3 tecumsehs all of about the same vintage as mower & all w/larger crank. Thanks for your input on this. Fred
Sirmowalot
02-12-2003 07:14:18
 Re: 70 JD w/7 horse motor in reply to Fred Kobs, 02-06-2003 23:49:32
What are you looking for as far as crank size? depending on application there are several sizes available and Tecumseh was good for making step down cranks. if you email me with the shaft dimensions you need and the engine size you are looking for maybe i can help
