1968 Wheelhorse Electro 12
Ken Taylor
02-11-2003 08:59:19
I am replacing O ring in Sunstrand Hydostastic trans. I need to remove some spline headed screws.What kind of tool can I use. Also, I can no longer find type A transmission fluid.What kind of transmission fluid can I use in my Wheelhorse?
William Pearson
02-11-2003 17:42:30
 Re: 1968 Wheelhorse Electro 12 in reply to Ken Taylor, 02-11-2003 08:59:19
Ken , You can change over to Dextron II or III and should change the fluid once a year or every 100 hours . Bill in Richmond , Va.
Wheel-Nut
02-22-2003 07:33:29
 Re: Re: 1968 Wheelhorse Electro 12 in reply to William Pearson, 02-11-2003 17:42:30
I believe the tool your looking for is called Torx bits. There is several styles, I prefer the socket with extended bits. Better leverage.
