Fuel pump for wheel horse
speed bump
02-15-2003 20:35:57
hello , need help on this one , just picked up a c-121 wheel horse, dont run , the guy says it needs a fuel pump . the fuel line is just hanging there bye the carburator and six or eight inches below the carb is a hole in the block where im guessing that this fuel pump would go . is this correct? and where can I get this. oh yea and while im at it I will need belts and wheel horse red paint for restoration. It has good spark and compression so hopefully I can get this fuel pump thing worked out . thank you very much for replies. speed bump
speed bump
02-16-2003 21:53:46
 Re: fuel pump for wheel horse in reply to speed bump, 02-15-2003 20:35:57
thanks so much for the info . the IH red I have from my farmall h restoration so im happy .I took off the seat asembly today and I couldnt believe the quality of this tractor . I mean a dipstick for the differential housing on a garden tractor , that is just too cool .I hope I can get these decals somewhere too . oh and by the way why does it say automatic on the hood when there is manuel gears . Im going too get both front tires fixed this week ( both flat) . cant wait too restore this gem too original glory. speed bump
Fred
02-16-2003 20:50:43
My 16 hp Massey Ferguson runs very good without the fuel pump.It has the kohler engine.
Wheel-Nut
02-16-2003 18:13:24
Speed-Bump, You can get the belts at any hardware store as long as its a high speed heavy-duty belt, At least that where I got mine. Works great. The red paint is really your choice, but IH red with almond white wheels is very close to factory colors.Hope this helps.Wheel-Nut.
Marvin Hylton Jr.
02-15-2003 20:42:42
Any small engine shop which handles Kohler parts should have a fuel pump or be able to order one for you.
rick
02-15-2003 22:58:11
 Re: Re: fuel pump for wheel horse in reply to Marvin Hylton Jr., 02-15-2003 20:42:42
Make sure that you clean the carb too. Who knows how long it sat there. Be bad to put a pump on it to find that the carb is so mess up that it still won't run. I really like my C120, dumped a Cub 125 Hydro to get it. Loved the Cub, but the C120 has cost a whole lot less to run. I till 3 acres of garden and mow 5 acres of lawn. The Wheel Horse has been a great tractor. One of my sons who kept telling me to get something newer that would mow faster has not said a word after I used the WH to remove sod, back fill and land scape his yard. The only reason I do not plow snow with it is because I live in MN on a farm with a very long drive. I have a 3/4 ton truck with a plow and HEAT in the cab. The heat thing is really important!!!!
