Anybody have a sleeve hitch?
daveA
02-19-2003 20:20:44
Hey I,m in the process of making a sleeve hitch.But I,ve never used one or see one in real life.I have a almost working proto type out of thin slotted steel I just bolted together.It,s going to be a single point like the ones Johnny Bucket sells for tube frames( My,s for a Cub 782)My questions are: do you think 3/16 steel will work?If I reinforce it by welding "L" brackets?What are the threaded holes for ,in the front?Are thier 4 holes at the piviot point?is one set of hole for pins to lock it down?How far past the rear tires should the hitch stick out?
