316 JOHN DEERE ENGINE REBUILD
MGinIL
02-19-1999 11:52:39
I HAVE A 16 HP ONAN ENGINE I WANT TO REBUILD. HOW HARD IS IT TO REBUILD? DOES ANYONE KNOW OF A GOOD SOURCE FOR A REBUILD KIT? DEERE ONLY OFFERS INDIVIDUAL PARTS, NOT A KIT. THANKS.
Russ
12-29-2000 21:59:23
 Re: 316 JOHN DEERE ENGINE REBUILD in reply to MGinIL, 02-19-1999 11:52:39
the one i have is single cyld aqs kohler you can buy what parts you need at any kohler dealer if you do a complete rebuild parts & mach work will be about 350.00 i rebuildt several 14hp this year & thats about what i spent thats new rod,pistion rings & gaskets turning crank & boring cyld best is to buy book from kohler gives you all the specs i have one if you need more info send email & i will reply good luck ps ihave about 8 JD tractors
David Castiaux
02-19-1999 22:07:34
It's expensive but not any harder than any other small engine. I did some major repairs on a 18 horse Onan a while back. It was in a Sears GT18, I didn't bother with Sears for parts I went to my closest Cummings dealer. Check it out in your phone book.I hope this is of some help,holler if I can help. David in OKC
Scott K.
02-19-1999 17:23:49
If it's an Onan, you'd better look a little closer at what you have. Deere got into a hell of a fight with Kohler awhile back over Koehler's refusal to stand behind the 17 hp engine that went into the 317. Deere decided to go with Onan at that point and the rest of the years run of 316, 317 and 318's all came out of the factory with 18 hp Onan engines. It sounds like you might have one of these.
