Case 444 hydraulics
Dennis Stoeser
03-05-2003 19:30:44
I have a 444 with cat "O" 3 point and a blade on the front. The cylinder for the front is under the tractor and the one for the 3 point is at the rear. Both are connected at the same point on the hydraulic unit under the tractor. They both connect to the same "T" fittings. They both go up and down together. I suspect some kind of splitter is missing. Any thoughts on this. I need to seperate them some how. Thanks
Max
03-05-2003 20:38:02
 Re: Case 444 hydraulics in reply to Dennis Stoeser, 03-05-2003 19:30:44
Nothing missing, that's the way they were supposed to be set up. At a dealership that I once worked at though, we installed a divertor valve so then you could select the mid hitch, raise the blade, then select the rear hitch and now the blade was in always up until you selected it again.
Max
03-05-2003 20:37:41
Max
03-05-2003 20:37:33
Max
03-05-2003 20:36:31
