Carburetor
Gene Davis
03-09-2003 14:35:44
I need to purchase a GOOD used, but not abused fuel tank and carburetor for a B/S 5hp engine, it is the older style side shaft engine that has the single screw through the air filter ,the tank under the bottom of the carburetor, and a screw on gas cap. Can anybody steer me in the right direction,or e-mail me with suggestion. Gene
Slowpoke
03-11-2003 22:37:17
 Re: carburetor in reply to Gene Davis , 03-09-2003 14:35:44
Check with mower rapair shops or junk shops for used items. Are you missing those parts? Sounds like a common 4 or 5hp B&S. I have the same setup on a Jari mower. The carb is mounted on the gas tank and is held on the block with 2 screws and there is a support on the bottom of the tank. What numbers are on the engine tag? There should be a model number, code number and one other which I can't remember now. They tell what carb you need. If you don't have a B&S, book send the numbers and I may be able to help you.
