430 oil
kjm
03-21-2003 15:29:59
Help, the owners manual won`t be here for 3 weeks. What type of oil for the hyd-stat and the moter? Thanks Kevin
Dave
03-21-2003 15:48:39
 Re: 430 oil in reply to kjm, 03-21-2003 15:29:59
Kevin - Here's the info from the 430 Technical Manual:
430 Diesel Engine Oil - SAE 15W-40 is preferred. If you use another viscosity, it's recommended that service interval for oil and filter changes be reduced by 50%. Recommended brand is John Deere TORQ-GARD SUPREME PLUS-50, or John Deere TORQ-GARD SUPREME, or other oil meeting one or more of the following API Service Classifications: CG4, CF4, CE.
If an oil other than listed above, John Deere again recommends reducing the service interval for oil and filter changes by 50%.
430 Transmission/Hydraulic Oil - John Deere HY-GARD or John Deere Low Viscosity HY-GARD. You may also use John Deere UNI-GARD or John Deere BIO-HY-GARD.
If you change the hydro oil, make sure you allow the old oil to drain completely, and change the filter as well. When installing the new transmission filter, fill 1/2 to 2/3 with fresh hydro oil.
Hope this helps. - Dave
Mark
03-21-2003 17:25:58
 Re: Re: 430 oil in reply to Dave, 03-21-2003 15:48:39
Good recomendations Dave low viscosity HY- Guard is the oil of choice because it takes the heat better in the small(garden tractor hydros), regular HY-Guard is not recomended by John Deere
kjm
03-21-2003 16:54:01
Dave thanks, dose the book say how many qt. it will hold?
Dave
03-21-2003 20:17:28
 Re: Re: Re: 430 oil in reply to kjm, 03-21-2003 16:54:01
Kevin - I should have posted the capacities earlier. Sorry about that. Here they are:
Engine Oil - 3.1 quarts without filter (The tech manual does not indicate the amount required with a filter change. However, I have to wonder if it might be a typo and is actually the capacity with a filter change.)
Transmission - 15 pints with filter change.
Dave
kjm
03-21-2003 20:34:09
 Re: Re: Re: Re: 430 oil in reply to Dave, 03-21-2003 20:17:28
Dave thanks a lot. kjm
