216 Deere transmission
Earl S .
03-24-2003 17:36:07
Is it best to remove the rear fenders and tank to remove the trans? Thank you for any help. Earl
jerry havel
03-31-2003 12:11:46
 Re: 216 Deere transmission in reply to Earl S ., 03-24-2003 17:36:07
as far as i know it's not possible to remove the transaxle without taking off the fenders and the gas tank. if it is your best bet is to take them off any way if they're not in the way for removing the transaxle they will be when you install it.
Earl S.
03-31-2003 17:03:38
 Re: Re: 216 Deere transmission in reply to jerry havel, 03-31-2003 12:11:46
Thanks for your help. Earl
jarrod
03-26-2003 15:33:56
Earl i think u will have no choice but to remove the fender. It is very easy to though. Remove all your knobs, two bolts up front, and 2 nuts at the rear. It will be a tricky to get it past the gear lever but be patient, it will clear it.I think u will have to loosen the brakets that your fuel tank sits between in order to get that tranny out.
Earl S.
03-26-2003 20:33:23
 Re: Re: 216 Deere transmission in reply to jarrod, 03-26-2003 15:33:56
Thanks for the help and comments. Earl
tim
03-26-2003 04:51:46
when your in trans also install new detent balls & springs cheep to do
Earl S.
03-26-2003 20:34:49
 Re: Re: 216 Deere transmission in reply to tim, 03-26-2003 04:51:46
Thanks for all the help. Earl
Dave
03-24-2003 19:42:35
Earl - It makes things a lot easier, and removing the deck and tank is really pretty easy. - Dave
Earl S.
03-24-2003 20:11:10
 Re: Re: 216 Deere transmission in reply to Dave, 03-24-2003 19:42:35
Thanks Dave I am about to jump into it .It has a noise in 3rd. gear. Earl
