Ford LGT 165 Alternator
John Koval
03-28-2003 20:12:08
I need to get to the alternator on a Ford LGT 165 with Kohler engine. I can see the wires disappear into the engine, but can't see the alternator or figure out what I need to take apart to get to it. Can someone help? Thanks!
Scott
03-31-2003 10:07:48
 Re: Ford LGT 165 Alternator in reply to John Koval, 03-28-2003 20:12:08
The stator under the flywheel doesn't go bad very much, most of the time it is the regulator, the wire going to the switch or the fuse holder in the harness.
Wally G.
03-30-2003 18:05:46
The stator assembly is under the flywheel. Pull the engine, remove flywheel blower housing, remove flywheel with a puller(DO NOT HAMMER ON FLYWHEEL) make sure all the magnets on the flywheel are still attached. The stator is attached with four screws to bearing plate.Make sure the voltage regulator on blower housing is good.
P D S
03-29-2003 09:42:14
I may be wrong but, Isn"t the starter the gen. also??
John Koval
03-29-2003 10:00:38
 Re: Re: Ford LGT 165 Alternator in reply to P D S, 03-29-2003 09:42:14
I guess that's possible, but it doesn't look like it. The starter just has one heavy wire connecting it to the starter solenoid. There are two wires going from the voltage regulator module which disappear into the engine; I assume they go to the alternator.
P D S
03-30-2003 08:19:42
 Re: Re: Re: Ford LGT 165 Alternator in reply to John Koval, 03-29-2003 10:00:38
Hi again. My guess would be that its under the flywheel then,which means pulling the engine.
Bob
03-29-2003 11:15:48
The alternator stator coils are enclosed by the flywheel, flywheel has permanent magnets inside it.
