1282/1200 Cub Cadet Mower Deck Swap
Hacksaw,The gra
03-29-2003 12:40:40
Help! I want to put the 44A deck from my 1200 on my 1282.The 1282 originally had a 38" deck with a 5/8 belt.44a deck has a 1/2 belt.I've got all the hangers figured out,now I just need to know what new pulley I need on the 44a and then what belt.Would changing the pulley be the easiest and cheapest way to convert to the bigger deck?I'm thinking maybe I need a pulley from a 44c or something along that line.?????
Wally G.
03-30-2003 18:00:46
 Re: 1282/1200 Cub Cadet Mower Deck Swap in reply to Hacksaw,The grass is Getting Green, 03-29-2003 12:40:40
Hacksaw, Use the pulley from the 44C but you need the lift frame for a 44 or 50 mower, the 38 is different. The front pulley set is different also, they angle off to the left side of the tractor where the 38 pulley goes to the middle.
Hacksaw
03-30-2003 19:08:47
 Re: Re: 1282/1200 Cub Cadet Mower Deck Swap in reply to Wally G., 03-30-2003 18:00:46
Thanks guys!
jimmy
03-31-2003 16:18:49
 Re: Re: Re: 1282/1200 Cub Cadet Mower Deck Swap in reply to Hacksaw, 03-30-2003 19:08:47
I have a old ford about a 1960 a 12 hp and I need a lawh deck it is I think about a 36 or 38 inch cut, the blades turn counter clockwise am wonrering where I can find one .thanks .jimmy
dvogtvpe
03-29-2003 19:11:53
yep , pully from the 44C will work
