Cub 1650 hydro valve type?
chuckc
02-22-1999 11:36:49
I have a 1650 hydrostatic cub & plan on adding a
extra hydrolic valve.I need to know if the valves
are Open Center or Closed center type?Also does
anyone know if this models tranaxle will stand up to pulling a small plow?
Earl
05-26-2004 17:44:48
 Re: cub 1650 hydro valve type? in reply to chuckc, 02-22-1999 11:36:49
i am lookng for a mower deck diagram to put back on to my cub cadet hydro 1650 can you help
Don
02-26-1999 17:25:57
I'm not sure on the hydraulics, but the rear in these tractors are HD. The only weakpoint is the axles themselves. They have a nasty habit of snaping at the wheel flange. If you have access to a service/parts manual on this tractor, Cub Cadet had a secondary "add on" hydraulic control for a power angle dozer blade. Parts may still be availible. Good Luck. Don
