Craftsman 917 Series
IneedSpecs!
04-04-2003 09:09:19
So here's the deal: I'm in Ag Mechanics class and need to find the specifications for a Craftsman 917 Series push mower. I've been searching all over the internet but have come up with nothing. If someone could please help out, that'd be great. I need to know the
Oil Capacity (fl oz)
Armature air gap (in)
Flywheel nut (ft lbs)
Cylinder head (in lbs)
Connecting Rod (in lbs)
Crankcase cover (in lbs)
Intake (in)
Exhaust (in)
Standard Cylinder bore (in)
Stroke (in)
Standard Crankpin Journal (in)
Spark plug gap (in)
Thanks again for any help!
Jax
10-08-2005 14:08:40
 Re: Craftsman 917 Series in reply to IneedSpecs!, 04-04-2003 09:09:19
good luck i cannot find anything on any tractor. Im tring to find specs on me craftsman tractor model 917.272121 no luck here. I need to know about the transaxel.
jax
Sirmowalot
04-05-2003 08:27:11
Your Craftsman is Actually an American Yard Product Mower. If you e-mail me at ltserr@valleytel.net with the complete model and serial number I can look up the dimensions for you. I am assuming at this time that the unit has a Tecumseh engine on it. If you can find the numbers on the motor it would be a great deal easier.
Papa Joe
06-08-2003 08:27:27
 Re: Re: Craftsman 917 Series in reply to Sirmowalot, 04-05-2003 08:27:11
i just found this this site & I have a similar problem. I have the original owners manual but it does not give the armature settings [air]. I sure would appreciate them. thank's for your attention the manual shows 914.255812 as mod. #
but I have hand scrawled notes on the manual showing----- hevy duty series 70 mod 110 82870100 ser c30 20384
spark plug settins .030" RJ12 plugs--just checked tractor can't find any info plates
mike
10-22-2003 12:09:20
 Re: Re: Re: Craftsman 917 Series in reply to Papa Joe, 06-08-2003 08:27:27
Papa --
I have the same machine as you do -- let me know what kind of info you're looking for and I'll try and help. Tried to send you email but didn't work.
Mike
